"menu ring" enum string
I have string commands and descriptions of these commands,
on the panel I want to have the descriptions of this commands
on a control that looks like a "Menu Ring" and on the diagram
I want to have a string as an output of this control (I need the
string commands for a serial hardware), e.g.:
String Command: Description of the command
B1: Configure as Pt100
B2: Configure as Ni100
Is there chance to create a string control that looks like a "Menu Ring"
and behaves like a "Enum" control?
I have two workarounds, but perhaps you have a more clever solution.
Regards, Stefan
(3,248 Views)
the code(vers. 6.0.2) ...
(3,245 Views)
I'm fairly sure 6.0 doesn't have it, but the combo box is what you want. Do you have it on the string palette?
___________________
Try to take over the world!
(3,240 Views)
