"real" RMS
Hello
To explain my situation.
I have some circuit(with LED), which input voltage must be from 7-16V. Input current is from 40-80 mA.That is enough that LED's glow. This is PWM "regulation".... This current is 100% true, and yes I can measuer with FLUKE "real RMS'' multimeter! This circuit also have "switch" for other working, constant DC 13V, current here is about 0,7A. This current I can measure in labview normally and all work's OK.(on picture you can see Statistics->aritmetic means-->......>current for constant DC voltage)
IN DAQ I define voltage and current, so there are "2 signal'", "one wire(4)" measure voltage, and on shunt resistor current..all is connected into SCXI-1000.. Now when I switch from normal mode, to PWM, I cannot measure current, logically because I need RMS, which I try to "make it".
I look some tutorials and examples on internet, and as you can see it I have problems.
Message 11 of 12
(734 Views)
The Fluke 87 True RMS multimeter has a bandwidth of 20 kHz.  You did not specify which model you have, but this is one of the better ones.  It cannot accurately measure your signal!
Lynn
Message 12 of 12
(728 Views)
