"self reference" vi labview 7
I'm searching in Labview 7.1 for a "this vi" reference node but can't find it. I know that it is possible to create one, i once did it. In higher versions of Labview it is available from the palettes. Do you know a solution for Labview 7.1?
(2,977 Views)
Hi vlipje,
you don´t need it. You can right click on the property node and select "Select class -> VI Server -> VI -> VI". This should also work.
Mike
(2,971 Views)
To get the reference to the current VI:
File I/O >> File Constants >> Current VI Path wired to Application Control >> Open VI Reference. This reference can be passed to a subVI over a VI Refnum control.
For working with the same VI the method of MikeS81 is prefered.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,963 Views)
Thanks Mike, this is a nice and clean solution, even better than what i had in mind..
(2,945 Views)
Indeed MikeS81 solution was what i was searching for. This one is also an nice solution, thanks
(2,943 Views)
