"single file" deployment
Is it possible to use Labview's Installer to generate a single file installer, like InstallShield?
 I  can zip the install Volume, but I'd prefer to have an single EXE for the installation.
(2,664 Views)
Not as far as I know. There's support files included that are required for the installer to work. One of these, for example, is the inclusion of Windows Installer. If you have WinZip then you can make a self-extracting installer that will automatically run the installer program. Many programs are distributed this way (including Microsoft updates). Another thing you may want to consider is a third-party installer like nsis. I've heard that mentioned on this forum a few times. I've never used it myself, so I can neither recommend it nor disparage it.
(2,648 Views)
Just pack the install volume into a single zip archive. Then make the zip archive a selfextracting  exe which will automatically start the setup.exe created by LabVIEW.
It is the same thing which Installshield does under the hood too.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,646 Views)
