"system global": polymorphic system global read_ami.llb
One of my project used the library above. But, i can't find its description.
Does anyone know where this library comes from?
Isnt that a common library?
thanks
(2,412 Views)
Hi craftindo,
it seems that the library you are describing is most likely a custom library not developed or included by National Instruments. Can you give me a bit more information about the filepath where you found this library and what you need the description to help you with?
(2,374 Views)
