"system launch" specific modules inside a library
Bonjour,
I use a large library (let's say this is necessary there) to store a large application with many user screens in it.
The modules all fall out into one application tree. Thus the root module is the one to be launched as "library top module" and I declared it appropriately.
But sometimes I would like to launch only one specific sub-module, not the "top" one, using a command line / system call. Is there a Labview command or tool to "system launch" specific modules inside a library ?
Thanks - oz
(2,691 Views)
LabVIEW accepts as a command line option the name of a VI to open or a library and a VI to open. So if in the \temp directory you have a library called lib_test.llb in whict there are the first.vi and second.vi, you can create a shortcut to LabVIEW with the property
'labview.exe c:\temp\lib_test.llb\first.vi'
and LabVIEW will launched opening directly first.vi
Roberto
(2,691 Views)
Thank you very much ! - oz
(2,691 Views)
