"wire frame" model of sphere in 3d
I am trying to make a "wire frame" model of a sphere using the 3d graph with LV5.1. Does anyone have any ideas as to how I could do this? I have been able to get the 3 circles corresponding to the x,y, and z axes, but it doesn't look like a sphere because there is no outer circle encircling the entire structure. Any ideas as to how I might be able to do this?
Thanks!
(3,093 Views)
A very straight-forward way is to take the 3-D example Torus.vi, open the diagram and you'll see a constant set to 3; set it to 0 and you have a sphere!
(3,093 Views)
In the same line as Alberto's answer, look at this tutorial at the Resource Library:
Using the 3-D Parametric Surface Graph
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&0FA53C35FFE09486862567FA0063A67D&cat=FFD0B3DB8F25D884862567930070A782
www.vartortech.com
(3,093 Views)
