"write to measurement file" specify column names
Have you tried to higlight the chunk of code you want to turn into a subvi, then go to Edit-->Create Subvi?  It will automatically create it for you.
Mason M
Message 21 of 28
(4,061 Views)
Ah, works like a charm.
Still getting the dreaded error -200279 (attempting to read samples that are no longer available) error in a relatively simple data acquisition system.   Any suggestions for good examples that show this?  When using the Express VIs, should we always use producer-consumer setups?
My data rates are low (1/sec!), and I thought I wouldn't see that problem, but I still do.
A.
Message 22 of 28
(4,049 Views)
How did you solve the Timestamp issue? I'm having trouble with the X-value turning all zeros after using Set Attribute.
Also, do you still have trouble with the for loop? I think I can help you. You need to wire in the string array with auto-index.
Message 23 of 28
(3,641 Views)
Can I ask how you fixed the timestamp issue?  As soon as I name the channels, I lose the time each data value was taken.
Message 24 of 28
(3,620 Views)
Helo I am QAISAR,
I have a problem during data storage by using write to measurement file. I am using DAQmax to acquire the real-time signal for strain by using strain gauges. When I save the data for the single channel by a write to measurement file it's automatically saved in excel sheet but when I use multiple channels the write to measurement file show error and stop the VI program. I attached the image that shows the error and LabVIEW program. Can anyone help me in this regards? I am very thankful to him.
Message 25 of 28
(3,091 Views)
You should make a new forum post for this question.
Maggie M.
Application Engineer
National Instruments.
http://www.ni.com/support
Message 26 of 28
(3,065 Views)
Hi everybody, I am very new to LabView (and programming in general!) and run into the same problem: I need to specify the column name on my saved file.
I understood the idea of a FOR loop around the Set Dynamic Data Attributes VI, but I really don't know how to do it, and how that can then be wired to the Write Measurements Data VI. Can someone post a proof of principle example, please? Thanks!
(PS somebody should make a YouTube video of it!)
Message 27 of 28
(2,273 Views)
Did you ever get a reply to this?
Message 28 of 28
(967 Views)
