"xterm" commands Mac
Hello
Using LabView 2009 on Mac OSX:
On my VI, I would like to place a button that when pushed will open a PDF of the instrument's instruction manual. I found what I believe to be a solution for a Windows operating system on this thread below...
http://forums.ni.com/t5/LabVIEW/system-exec-vi-wont-take-multiple-cmd-line-options/m-p/1120009#M4944...
But I cannot get it to work on Mac OSX (not surprising). I cannot find a Mac equivalent. Using X-Terminal, the command is simply
"open InstructionManual.pdf" when in the correct directory.
Can anyone please point me to a subroutine that will either allow me to use an X-Terminal command or a Mac OSX system command that will open up a PDF?
Thanks very much.
(4,039 Views)
Accepted by topic author CodeMunkee
I think you can do it with the System Exec.vi (Connectivity palette) although I have not done that in quite a while so I do not recall the exact format.  The image below shows how to use Apple Events to open a PDF.
Lynn
(4,020 Views)
Hey CodeMunkee,
You do have the option to open the PDF as an ActiveX control.  Please see the community example Open PDF in LabVIEW.
Lynn
Senior Systems Engineer
(4,003 Views)
Lynn,
ActiveX is not available for the Macintosh, which CodeMunkee is using.
Lynn
(3,998 Views)
Thank you!
For anyone else with a similar issue: in LabView 2009, go to Data Communications>>Protocol>>AppleEvent>>AEFinderOpen
works like a charm. specify folder, then file.
One final question... for mass distribution I plan to have the PDF in the same folder as the VI (which will be a *.app). What is the right way to specify "current folder"? I thought I could just do this
as the current file (that's a period for the current folder, then a colon) and then indicate InstructionManual.pdf as the file, but it didn't work. What am I doing wrong?
Thanks a ton.
(3,985 Views)
Hey CodeMunkee,
You could try using the Current VI's Path Function with the Path to String Function.
Lynn
(3,964 Views)
