radio button no selection when I start the application
hallo,
i have a radio button with some buttons in it. I would like that when I start the application none of the buttons is selected. There is a "allow no selection property", but this only allows the "no selection". My problem is that when I run the vi, one of the radio button is on and I would like all the buttons off.
thanks
Message 1 of 11
(6,315 Views)
Initialize it like this:
Jim
Message 2 of 11
(6,313 Views)
thanks for the suggestion. I'm really new to Labview... and I don't know how to get that "no selection" rectangle.
Message 3 of 11
(6,285 Views)
Right click the terminal and select "Create"/"Property Node", selecting the "Value" property.  Right click on the property node and select "Create"/"Constant".
Steve
Message 4 of 11
(6,283 Views)
Accepted by davico
aha, thanks a lot. It works
Message 5 of 11
(6,278 Views)
Ha!  I'm glad you could help. 😄
Jim
Message 6 of 11
(6,257 Views)
You should mark Jim's answer as the solution, not your own comment.
p.s. Jim, can't you also do that with a Local Variable?
Richard
Message 7 of 11
(6,246 Views)
Yes.
Jim
Message 8 of 11
(6,232 Views)
Actually I think my guy Steve get's the "Solution" or at least an assist....
Programming with local variables is like (How to say it ?....) Self-abuse.  You can get what you want but, please don't do it in public.  Smiley Wink
Message 9 of 11
(6,202 Views)
I agree with that statement in principal, but I strongly disagree that using a local in this example (in this thread) would be abuse.
Richard
Message 10 of 11
(6,176 Views)
