radio button with number
Hi all!
I’ve seen a lot of discussions concerning this topic, but no one fits my problem.
I want to set a radio button control with two options, and a numeric value associated to one of them (offering the user the possibility to select a global attenuation, which is the numeric value, or made use of a calibration file) for the 4 instruments used in the measurements. (see example and image attached)
I’ve tried to edit the control, but it gives me an error as soon as I place the numeric control. If I add it directly in the front panel, an undesirable shadow appears…
Any idea?
Mensaje editado por Gatet
(3,925 Views)
would using events for each radio button and make that numeric control visible/invisible as shown in this VI help??
I am not sure if X controls can be used to realise this kind of an application.
(3,907 Views)
(3,907 Views)
Hi Gatet,
you can't insert a numeric control into a radio button, because this changes the type of control and consequently giving you the error.
I was facing this same problem recently and got an answer here:
http://forums.lavag.org/index.php?showtopic=2883
Besides ignoring the issue (the shadow disapperas dring execution) probably the easiest solution is grouping the controls.
Good luck,
Guenther
(3,905 Views)
Hi devchander,
I'm using LabVIEW 7.1, so I can't open your example (requires 8.0). Could you please store it for this older version?
Thanks!
(3,897 Views)
In LabVIEW 7.1
Message Edited by devchander on 07-31-2006 06:25 AM
(3,892 Views)
Hi again devchander,
this solution looks nice, but i rather prefer to leave the numeric value, so the user can easily compare it. Furthermore, I try so far as possible to avoid event structures!
Thanks anyway for your time, also to all others. With your help I got what I was looking for,which looks as the example attached.
Cheers!
(3,884 Views)
