radio buttons
i want to transfer data of radio buttons from one pc to another using tcp/ip protocol. how can i do it?
Message 1 of 10
(6,380 Views)
Are you able to transfer the data over TCP/IP? or else you want to know how to use radio button?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 10
(6,356 Views)
Hi arushi,
how can i do it?
Read the value of the radio button on one pc, send it with a TCP message to your other computer and display the value over there…
What exactly is your problem? Where are you stuck? How does your VI look like?
Message 3 of 10
(6,354 Views)
i have attached the vi which shows both client and server side. when i run the vi i want that the checkbox which i select on server should be displayed on client side and correspondingly the object in case structure shuld be displayed
Message 4 of 10
(6,349 Views)
Hi arushi,
there is no TCP server and no TCP client.
Your VI contains just an event structure!
LabVIEW comes with alot of example VIs. Open the example finder and study them! (There are also examples of TCP communication…)
Message 5 of 10
(6,341 Views)
this is the correct one
Message 6 of 10
(6,315 Views)
Accepted by topic author arushi31
Hi arushi,
- in the server you call TCPWrite two (2) times, in the client you call TCPRead three (3) times. This doesn't fit…
- in the client you read 10 bytes to check the size of the message - but you just wrote 4 bytes as "size". That doesn't fit together…
- when running all local you should use "localhost" instead of a fixed IP address…
Message 7 of 10
(6,311 Views)
thnku so much this was really helpful,  but i cant tranfer the data while the vi is running. so is there a way out
Message 8 of 10
(6,304 Views)
Works fine for me once I made the changes GerdW already told you to make.
You could potentially be running into corporate firewall blocking the port you are trying to use.  Try a different port.
Message 9 of 10
(6,290 Views)
Hi arushi,
after I changed the points I mentioned before I was able to run your VI successfully…
Message 10 of 10
(6,287 Views)
