ramp and soak using labview
hi,
i need to ramp temperature at a rate of 1C/min.
i have thermocouple connected to a block whose temp i need to
increase. This block is resistively heated using a power supply. The
power supply accepts 0-10 V dc input and gives 0-25 amps output.
this is controlled using daq cards from NI. Can some give me some
clues on how i can do this ramping in labview.
thanks in advance,
sulekha
(3,524 Views)
I wrote a timing toolkit that includes a ramp and soak example VI. You can
download it at:
http://www.calbay.com/timing/GOOPTimer.htm
-Jim
"Sulekha Chattopadhyay" wrote:
>>hi,>i need to ramp temperature at a rate of 1C/min. >
heated using a power supply. The >power supply accepts 0-10 V dc input and
gives 0-25 amps output. >this is controlled using daq cards from NI. Can
some give me some>clues on how i can do this ramping in labview.>>thanks
in advance,>sulekha
(3,524 Views)
Thank you, i shall try it out.
> download it at:
> -Jim
> in advance,>sulekha
(3,524 Views)
