ramp-generate
Message 11 of 14
(1,562 Views)
I'm not quite sure what exactly you're trying to do. There's no reason you cannot use a case structure with a for loop, unless I'm really misunderstanding what it is you're trying to do.
It's possible you may find this example helpful: https://decibel.ni.com/content/docs/DOC-14687
They generate their ramp in a different way, but the idea is still the same: generate the waveform that you want to output and then send it to a device as many times as you want it repeated by using a for loop.
Message 12 of 14
(1,523 Views)
I want to generate continous ramp wave from  -7v to +7v .can u help me.
Message 13 of 14
(1,384 Views)
Have you tried the example BriceS posted? It seems to be what you're looking for. You can just change the min and max voltages to -7V and 7V respectively.
Message 14 of 14
(1,349 Views)
