ramp voltage generation
Hi all,
Can I create a ramp AO voltage using NI USB 7856R? Or do I have to integrate it with some labview program for ramp? If then how can I do it?
Message 1 of 11
(5,292 Views)
I'm pretty sure you have to (programmatically) tell it what you want it to do.  I think NI is actively working on a version of their hardware that will predict the waveform the user wants (such as a ramp, with parameters), but I expect that's a few years away.  Until then, you probably have to send it the ramp waveform you wish to output.
Bob Schor
Message 2 of 11
(5,252 Views)
Hi bob,
Thanks for your reply. I am attaching a picture of inbuilt analog output program for NI usb 7856r can you tell me how to make it ramp? How do I integrate it?
Message 3 of 11
(5,238 Views)
Hi basimass,
create the ramp data in your host VI.
Then send the AO data from your host to your FPGA target.
There are a lot of functions in the Signal processing functions palette, I guess one of the will fit your needs…
Message 4 of 11
(5,234 Views)
Hi
I put ramp equation to the connector fpga and I got a signal like ramp. Now I want to slowly rise the ramp, I mean 10v/s. I put a timer but its not working. Any suggestion? Attaching image of what I have done.
Message 5 of 11
(5,221 Views)
If you are comfortable with it, I suggest you generate the waveform in the FPGA.
Can you provide parameters of the ramp?  Levels, ramp time, number of steps, does it need to repeat?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 6 of 11
(5,218 Views)
Hi basimss,
Think DATAFLOW!
Your wait function is pretty useless regarding those for loops. When you want to slow down those loops you need to place the wait inside the loops...
Message 7 of 11
(5,217 Views)
Actually what I want to create is s ramp which rises 1v/s ,using fpga Ni usb 7856R ,which can be observed using oscilloscope and when I click stop it should show a constant value.
Message 8 of 11
(5,200 Views)
Hi basim,
some simple pseudocode:
// t1 = loop iteration time in seconds
rampspeed := 1   // 1 V/s
ao := 0
step := rampspeed * t1
REPEAT
  ao := ao + step
  wait(t1)
UNTIL "stop button"
Looks really simple to me.
(In your image you don't even place the timing in the right place…)
Message 9 of 11
(5,198 Views)
Hi
It will be helpful if you give me some labview programs( block diagram) that could work since I am new to this.
Message 10 of 11
(5,192 Views)
