random build errors that go away if I just keep building
I'm having a problem where my program will build fine but only after I try to build it around 4 times with build errors.  One example of an error I get commonly is :
LabVIEW:  Generic file I/O error.   Anyone have a similar issue where it will build eventually but takes a few trys?
(2,402 Views)
I think it has to do with LabVIEW and the Windows file indexing service battling over ownership of files. Try putting your build directory in a non-indexed directory.
LabVIEW 2012
(2,400 Views)
Accepted by topic author acolbourn
I believe my problem is fixed.  I was attempting to build into a dropbox folder which seemed to be causing issues for some reason, building to the desktop seemed to work.
(2,380 Views)
