random number generator generate one by one
ONLY when the boolean is true, i would like the random number generator to generate one number.
when i press the boolean again and its true,  would like the random number generator to generate another number
how do i come around doing so?
(3,102 Views)
Please find attached VI
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(3,094 Views)
Sorry, but I have to critique the example code given.
There should be a way to stop the VI without using the abort button.  Add a stop button and add an event to handle it (supply the TRUE to the while loop's termination).
There is not need for the timeout in this case.
(3,070 Views)
