range of number in numeric control
hi,      im new to this program and im trying to generate a range of number (ex. 5.0 1.0 0.25 and 0.10) using a numeric control. can anyone please shed some light? thanks.
(2,935 Views)
It is not entirely clear what you really want, but you could just create an array control showing 4 elements. For that, you would first drop an array container on the front panel, the drop a suitable numeric control inside it. Now resize the container (horizontally or vertically) to show as many elements as you want.
On the block diagram you would get a 1D array terminal.
Message Edited by altenbach on 04-08-2007 07:50 AM
(2,911 Views)
Are you trying to programmatically generate those numbers?. If the numbers that you are trying to generate follow a certain pattern. you could use a "For Loop" to generate them. Please provide more infomation so that we can further help you.
Rudi N.
(2,892 Views)
thank you for your replies... sorry for the delayed response. thanks again.
(2,852 Views)
