raspberry PI Camera connection with LabVIEW
Hello Everyone,
I try to connect my raspberry pi cam to the LabView, in order to take image with it using a vi program.
Following Software and Hardware I use:
- Raspberry Pi 4 (Model B)
- Raspberry Pi Camera Module 2
- Ethernet Cable connected to my Laptop
- LabVIEW professional 2020
- LabVIEW vision assistant, IMAQ and vision aqusition
I have also downloaded the LINX-Tool but I heard tha it may only work with LabVIEW 2014. I have tried to connect the PI using the LINX-toolkit but it didn't work. So I have created a html webpage to stream my pi camera in real time. I can access to this livestream typing the IP-Address of the raspberry pi. Is there any way to have an access to the camera using the IP-Address ?
If there is also another way to include the camera in labview, I will be very appreciated .
Thanks in advance
Message 1 of 1
(2,088 Views)
