re-initalize Listbox to default values
Using LabVIEW 2010.
It seems that an Invoke Node to Reinitialize to Default for a Listbox does not work. I have to wire an empty array to the Listbox's Item Names Property Node.
Am I doing something wrong?
Message 1 of 19
(4,432 Views)
Accepted by topic author nyc_(is_out_of_here)
mmm, I tried it myself, and it doesn't work either.
In the other hand I used to initialise them by wiring a constand empty string.
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 2 of 19
(4,431 Views)
Reinitialize To Default (whether done programatically or from the front panel, only affects the Value of a control, not any of the other properties (such as the items in the list).
Message 3 of 19
(4,382 Views)
The "value" of a Listbox appears to be the selected items index and not the items in the Listbox.
Just seems odd there is no quick way to clear out a listbox short of wiring an empty array.
Message 4 of 19
(4,377 Views)
I am learning labview, How do you wire a constant array string constant to the listbox?
Thank you
Message 5 of 19
(1,413 Views)
You create a property node for the listbox and choose 'ItemNames' for the property node.
Something like in https://forums.ni.com/t5/LabVIEW/Add-text-line-to-list-box/m-p/2123850#M689210
Message 6 of 19
(1,400 Views)
Thank you very much it worked, However, i have another question if you don't mind.
i have a list of 3 columns and n rows ( # of players that show up). The columns consists of : #players.....players names ....and... paid dues  .My problem is the paid dues...I cannot figure an array of players that haven't paid yet. I can total the dues that were paid  but not the names of the players that haven't paid. I hope it's clear enough.
Message 7 of 19
(1,349 Views)
i have a list of 3 columns and n rows ( # of players that show up). The columns consists of : #players.....players names ....and... paid dues  .My problem is the paid dues...I cannot figure an array of players that haven't paid yet. I want to have an output of the players that haven't paid yet programatically. I can total the dues that were paid  but not the names of the players that haven't paid. I hope it's clear enough.
Anybody.....
Message 8 of 19
(1,314 Views)
Iterate over the 2D array of strings and use a conditional tunnel that auto-indexes the second value (player name) for all row where the third array value is an empty string.
Modify according to the exact requirements.
Message 9 of 19
(1,311 Views)
I tried it. it didn't work for me. May be i did not know how, Can you show me an example, I'll appreciate it.
Message 10 of 19
(1,305 Views)
