re post my problem vi with results (localDSP)
note:there is no results on the second graph but it is definitly reading something because auto scale jumps around in sink with scaled data vs time
"unable to read the freq and amplitude"
"if you could look at the prog.s attached and if you can explain why i am unable to read the data output from "scalled data vs seconds" into tone measurments.
it must have something to do with the conversion from the cluster of 3 elements to the DBL waveform can anyone see the mistake in the conversion!!"
(2,413 Views)
Your data are still not saved as default on your graphs. To do so you have to run you VI and when the results are available, go to Operate>>Make current values default before saving your VI.
However this may not needed because I can see that the frequency and amplitude results (saved by default) are f=2.3456kHz and A=1.000xx V. These values look reasonable to me. What values are you expecting?
(2,413 Views)
