reach display
I am trying to use a 7 inch display from Reach Technology. I am trying to run labview on a sbRIO 9636 board.
I am running into problems with the drivers provided by NI, in particular with Extended Data.vi . It is giving an error. There seems to be a wiring error.  A renamed Exnded Dataerrors.vi file is attached. Would greatly appreciate any help.
Al
(3,539 Views)
There are multiple wiring errors.  Where did you get this VI?
You can't build an array where you put a scalar element onto a 2-D array.
You also have a search 1-D array where there is no 1-D array wired into to be searched.
(3,520 Views)
(3,476 Views)
Hello adilansari, have you tried checking the suggestions of
(3,451 Views)
