read UDP data from a server on which labview server code cannot be run
Hey i have fair practice on labview fpga but i am new to labview communication protocol side.We have an automated weather system whose sensors are connected to a MCU which is further connected to a server over ethernet. By connecting my laptop via LAN to network switch,i can get access to  incoming UDP data packets directly from MCU as there is no way i can get access to server due to system restrictions. I want to make a Labview GUI in which the UDP data packets containing sensor data arrive and display all the measurements but all the examples i studied require labview code to be run on both server and client PC which is not possible for me.kindly someone help i am really confused on this topic and have not been able to make a single vi due to these questions in my mind
regards
(2,670 Views)
Accepted by topic author Mrsnaveed
Examples need to show both ends of the communication.  If you don't need the sending end, then just pay attention to the receiving end in the example.  Understand how the data that is coming in from your remote devices are structured,  receive that data, and parse it out to do whatever you want with it.
(2,667 Views)
