read/acquire signal from remaining empty channels of NI9205 by modifying the vi of ATI Force/Torque Transducer which uses the first 6 channelsof DAQ card.
I am using force/torque transducer by ATI Automation. It provides me with its own vi to measure and write the data of the 6 signals (3 axes Forces, 3 axes torques)
Following is my Ni system: -
cDAQ 9172 chassis: Slot 5 - NI 9401, Slot 6 - NI 9205, Slot 8 - NI 9237. (Excitation voltage to the sensor/transducer (0-5V) using 9237).
I connect the 6 signals from the transducer cable to channels ai0,1,2,3,4,5 in NI 9205(differential). The vi uses a calibration 6*6 matrix to finally display the calibrated voltage data.
Now, I wish to use the remaining availabe channels that empty in 9205, namely ai17, ai18, ai19 for other signal measurements.
ai17 channel is connected to Hall sensor  that gives out a square waveform corresponding to the rotor rpm. ai18, ai19 is connected to rotor-motor power supply's voltage and current signal respectively.
But I am not able to access these 17, 18,19 channels from ATI company's vi. The vi loads the complete DAQ card (9205), uses only first 6 channels, hence the array data wire consists of only 6 channels. I can split these into 6 individual signals only.
If I use a separate DAQ task to read channels ai17,18,19, then I get the error that this channels are reserved for some other task. Please tell me how can I access all the remaining channels apart from the first 6.
I am attaching the vi here.
Steps to run the "MEASUREMENT main.vi" : -
Load calibration file:-  FT8840.cal;
Load DAQ card: NI 9205
Load ctr0 of NI 9401 (I am using this counter for rpm measurement purpose, this is my addition to the actual vi)
(3,162 Views)
That's because you can only have one task for a particular card running at a time.  Trying to create another taks for the same card in another VI causes the error you see.  The DAQ timing clock has already been reserved by the first VI.
You will need to take their VI and modify it to add the additional channels into it.  That or recreate what they are doing in your own VI.
(3,147 Views)
Yes I know I can only run one task at a time for a particular card. That is why I asked for help, if you can help me with modifications I might have to do the vi. I attached the vi in my previous post.
Thank you.
(3,100 Views)
There's nothing I can do to help.  I don't have your hardware to be able to modify your code and to set it up to make sure it runs properly.  Most people on the forum probably don't either.  This is where you'll have to put your programming and LabVIEW skills to work to solve your problem and make it run the way you want to.  If you run into a specific problem and get stuck, then please post back.
(3,097 Views)
