12-22-2014 03:26 AM
hi sir i am read excel sheet using labview ,but unable to plot the selected colomns,so its needfull ,please find any body to sollution to the problem .i i already did some part ,it is take too much delay
12-22-2014 03:01 PM
You need to attach all the files in the project not just the project file itself.
For more information and some sample VI's and tool kits, you can go to the excel board
12-23-2014 10:33 AM
First, you are not reading an Excel sheet but a text file (a csv file is a text file). From the listing of the function used (from the lvproj file) you are using the Read From Spreadsheet function, this function will return a 2D array. Use the Index Array function to extract the x and y value columns. Bundle them (using the Bundle function) and wire the output to your XY-Graph.
Ben64
