read and sort values present in .ini file
Hi all,
I have a .ini file in which a set of modules with there order of execution is mentioned.I want to get all these values sorted as an array so that I can proceed with the execution of each in the order mentioned.The module list in the .ini file looks like this:
Here, digits represent the order of execution of module.
I should get output as an array with following values:
1 MNO
2 DEF
3 STU
4 PQR
5 GHI
6 VWZ
7 ABC
8 JKL
I know about config data and read key vis but since the module list is huge I dont know how to write an efficient code for this.All suggestions are welcome.
Thanks.
(3,195 Views)
Accepted by topic author mnx
The snippet below should be very close to what you want.
(3,181 Views)
Hi,could you please post the vi for this.?
(3,173 Views)
Thanks nathand..I got it..:)
(3,169 Views)
