read and write on to the reflective memeory using a sub vi
i need to call a sub vi from the main vi which could do the read and write operations onto the reflective memory ,i am new to lab view please advise.
(2,849 Views)
Hello chinna,
what do you mean by "reflective memory"?
(2,848 Views)
Are you referring to a VMIC Reflective Memory device? If so, National Instruments has created a LabVIEW instrument driver that is available for download. The link to this instrument driver download, as well as a useful KnowledgeBase article: NI and our Reflective Memory solution.
Also, you might be interested in the following tutorial Communication Mechanisms for Distributed Real-Time Applications.
Good luck!
Kileen C.
(2,848 Views)
