read and write with usb printer
hello friends
                        i m new in labview . can any body advised me how to read and write with printer that have USB interface . because latest printer connection are usb based not parallel port based.
any example or material.
i shall be very grateful to u
thanks
(3,039 Views)
Can you give us the specific model number and manufacturer of the printer?? If it shows up in windows as a printer port, you may not have to do anything special if you just want to print from labview.
(3,034 Views)
It depends on what type of driver you are using, and how that driver communicates with you printer.
There are lost of different ways LabVIEW can interface with external hardware, either using all libary function node, ActiveX, .NET, etc.  It all depends on what type of driver you are using.
Regards
Seamus
(3,007 Views)
