read any point from x y arrays
I have 2 arrays x and y these contain coordinates the plot a curve on a xy graph. I need to read the y result at any x point, I thought of using Interpolate function but this will only read in the y array as a linear  and not the curve which is a result of x and y. Any help would be much appreciated, thanks.
(4,580 Views)
Why not combine the two arrays into one 2D array? Then you can pair up each x value with the associated y value. Once you have the data organized this way, you can index that 2D array to get any x-y pair.
(4,567 Views)
Are you specifically looking to get the Y value for an X value that is not in your array? If so then you either have to interpolate or create a curvefit that will give you a y=f(x) function. For interpolation the built-in interpolation let you decide what kind of interpolation to use. The shape of your curve and how close together your points are will dictate which method is best.
(4,562 Views)
Assuming the x-array is sorted low-to-high, you would use "Threshold array" on your x-array and then use the resulting fractional index to use "interpolate 1D array" on the y-array.
Here's an very old example:
(original thread from 2004)
If your xy data is more complicated (e.g. containing loops), things are no longer simple, because there are possibly zero to multiple y-values for a given x.
Message Edited by altenbach on 05-05-2009 03:03 PM
(4,553 Views)
Corollary: If it's not, the Threshold 1D Array VI (Mathematics -> Interpolation & Extrapolation) could be used as X does not need to be monotonic for that VI, though it's a bit annoying in that you have to feed your X value as an array even if you're just interested in 1 value.
Message Edited by smercurio_fc on 05-05-2009 05:16 PM
(4,546 Views)
Thanks very much for all your help, the curve is rising and I am  looking for the y at any given x point ( the points in between my coordinates inputted in the arrays). I will try all your suggestions and let you know, thanks again.
(4,523 Views)
