01-28-2011 04:24 AM
Hi
Im using Labview in order to acquire data, by DDE link, from an FT-IR analyzer.
The DDE request output is a string, but i need to read bit status (like1011100... etc).
How can I transform string output in bit pattern??
I hope somebody can help me.
Thank you very much
Antonio
01-28-2011 05:51 AM
Hi Antonio,
you can use the "String to Byte Array" function. With "index array" and "number to boolean array" you can get the single bits.
Hope it helps.
Mike
