read bmp -> modify -> write bmp
I would like to read from a spreadsheet file a path to a *.bmp file, then combine a Comment (String-value) to that *.bmp file and save it.
What's the best way doing it with LabView 7.1?
Y3G
(2,872 Views)
Hi Y3G,
use the "read from spreadsheet file.vi" to read your data and combine your strings with the "format into string" function.
Mike
(2,865 Views)
Are you referring to embedding a comment in the actual bitmap file? If so, as far as I know, a bitmap file does not support comments embedded within the file.
(2,861 Views)
Are you adding the comment to the filename?  I think you could use the Move function under the Advanced File I/O palette to do a rename.  There may even be openG VI's that do this as well.
(2,859 Views)
