read data from Serial communication with DB 9 and move cursor position
 I am doing a project using arduino board, i connected an xbee module to the board and db 9 cable from board to PC(windows). i am getting sensor values on hyperterminal of PC. Is there any way by which i can read the values from hyper terminal and do mouse operations.
Eg:   Suppose i receive letter L on hyperterminal i have to move cursor left
R- right
U-Up
D-down
C-click operation
Message 1 of 9
(4,011 Views)
I wouldn't try to do anything with Hyperterminal which has become outdated and unsupported.
I would use the VISA functions already in LabVIEW to read and write to the serial port directly.  Search LabVIEW examples to find example programs for communicating with the serial port.
Message 2 of 9
(4,003 Views)
Thank you for your information, and do you have idea of moving cusor position with the data which has been read...?
Message 3 of 9
(3,995 Views)
Message 4 of 9
(3,993 Views)
Where is the mouse supposed to be? On the desktop, inside a Windows app? If so, what is the application? On a LabVIEW front panel?
These are the sort of details that should have been included in your original question.
Message 5 of 9
(3,983 Views)
Actually my project is to move mouse pointer in the direction of a persons head tilt. So the windows app can we develop using LABView...?
Message 6 of 9
(3,958 Views)
When you talked about a cursor and hyperterminal, I thought you were talking about the cursor you'd have within a hyperterminal window, or like you'd have in Word or Notepad.  Now that you are talking about the mouse pointer, it is a little clearer.
If you can detect the mouse position, you could adjust the coordinates accordingly and some action happens, then set a new mouse position.  Right now I can't find a  means to determine or set the mouse position within a LabVIEW panel.  Of course if you want it to work even outside of LabVIEW, I doubt you'll be able to do it with a LabVIEW property or method.
Though I bet there is a means through a call to a Windows .dll such as User32 that could do that.  But, I've never tried to do it myself to be sure.
Message 7 of 9
(3,947 Views)
You could plot it on an xy graph. What is the click operation?
Message 8 of 9
(3,945 Views)
You will have some icons or folders on desktop which you need to select using head movement. Selecting these things am considering as click operation(generally double click in mouse)
Message 9 of 9
(3,934 Views)
