read data from .prn file
I need to read the columns from a .prn file containing only numbers. I tried using "Read from a textfile.vi". Only the first column was returned. Probably the formating style needs to be specified. But I don't know how. Will anyone provide a detailed answer.
I have also used "Read line from a fie.vi" to obtain the rows in the file. But how do I extract the individual data for each column in a row? There must be a vi which I have not explored yet.
(3,438 Views)
Use "read from spreadsheet file".
Make sure you wire the correct delimiter according to your data (e.g. comma, tab, space, etc.).
If you still have problems, attach a sample data file so we can have a look.
(3,432 Views)
