read data from .wav file
I am new to labview. I have acquired data from a sound file represented it graphically and at the output of read sound VI I have placed indicator which is indicating it to be an array. since the size of array that is shown to me is 1. I have checked on matlab the sound file is of 44556x1 length. Now further I want to extract few elemnts of array when I have placed array subset VI it does not take the output of Read sound VI as its input.Why this is so?when the read sound VI indicator is array.
(2,705 Views)
Hi!
Can you send the source VI ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(2,700 Views)
Which version of LV are you using, because inn LV 8.5 the output is a waveform array and it perfectly connects to a graph indicator and array subset.
Which sound file format do you use? Could you post the sound file or a sample in the same format giving just noise?
Message Edited by andre.buurman@carya on 11-30-2007 09:28 AM
André (CLA, CLED)
(2,691 Views)
