read data with trigger usb-6210
Hello
I'm using LabView 8.6 full development
First sorry for my english
My problem is: I'm using USB-6210. I connected a encoder signal to one of digital inputs and then generate trigger signal according to encoder. Now I need to read data from 4 analog inputs at the rising edge of trigger. But I must read all data at one time. I have around 200 measurements points. So my idea is: when the trigger appears card read data, but I not taking them. I take data when card have all 200 measurement points. Is it possible to do with this card? and how. Frequency of trigger signal is around 1kHz
Bartek
(3,289 Views)
Hello Bartek,
If I understand correctly, you need to start Analog Input (AI) measurement on 4 AIs with rising edge on digital input (DI). Moreover, you want to read all configured samples at once.
If I understand correctly, than you need to perform Finite Samples AI Acquisition with Digital Start Trigger.
I strongly recommend to read some manuals to get familiar with your device. I would start with M Series User manual, which I personally consider to be very useful for finding most important information about your device. Moreover, there might be some "specialties" for USB-6210, which you might find in NI USB-621x Specifications.
Please go trough following sections of recommended manuals:
  1. AI Start Trigger Signal - M Series User  Manual page 4-35
  2. Chapter 11, Triggering of M Series User Manual
  3. NI USB-621x Specifications - page 9, External Digital Triggers
 If you wonder how to realize the measurement in LabVIEW, I would point you to Example Finder, where you can actually find such a example.
  1. In LabVIEW menu, open Help -> Find Examples...
  2. Navigate to Hardware Input and Output -> DAQmx -> Analog Measurements -> Voltage
  3. Open Acq&Graph Voltage-Int Clk-Dig Start.vi
 I believe this example should perform exactly what you need.
Martin Stefik
Application Engineer
Czech Republic
(3,270 Views)
