read digital line e series
This has got to be the simplest question, but how do I read the line state of the PFI lines on my 6024E board?  The 'digital channel' 0 is the only port I can access but I'm using those.  If I set the channel to '1' there's an error.
How do you get at those other bits?
Message 1 of 8
(4,211 Views)
What is the error u r getin?
Message 2 of 8
(4,192 Views)
A window pops up that says:
Error - 10007 occurred at DIO Port Config
Possible reason(s):
NI-DAQ LV: A channel, port, or counter is out of range for the device type or device configuration; or the combnation of channel is not allowed; or the scan order must be reversed (0 last)
Can someone walk me through how to configure the digital i/o pins, and how to read individual pin states?
Thanks much!
Message 3 of 8
(4,185 Views)
I'm a tad confused. The 6024E only has one digital I/O port, so you would obviously get an error if you tried to read port 1 since it doesn't exist. The DAQmx examples that ship with LabVIEW show you how to perform digital I/O. Have you looked at these?
Message 4 of 8
(4,169 Views)
Well that would explain it!  Maybe I'm misreading this document:  http://www.ni.com/pdf/manuals/370719c.pdf
but it looks like the PFI lines are available on the 6024E in addition to the 8 I/O lines.  But then you're right, at the end it says only 8 I/O lines.
Message 5 of 8
(4,162 Views)
Not sure which part of the document you're referring to. The table listing the lines indicates the PFI lines as "DIO" but that's in terms of their type, not their function. The PFI lines are "Programmable Function Interface" lines, and aren't really designed to be used as digital I/O. They're there to perform functions, such as triggering analog input or analog output, or counters, etc.
Message 6 of 8
(4,160 Views)
Oh, I thought since they are on the BNC-2110 terminal block that I could use them for digital I/O.
Message 7 of 8
(4,154 Views)
And by the way, thank you.
Message 8 of 8
(4,153 Views)
