read file .csv with 2 columns to labview?
I have a file .csv with 2 columns and a lot rows, i want to use this data, but i only get read the first column.
Any advise?. I attached the program and file example.
(2,571 Views)
Hello Fonsi
Please, check your example file. If you read it as txt, the separator is a semicolon intead of a comma.
I think this is the problem.
Regards
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,571 Views)
Hi Alipio, Thanks it works, i put delimiter ';' and run.
Regards, Fonsi!
(2,571 Views)
