read file stored on flash Momery
Hi..!
I'm  planning to list files stored on flash momery. I need a clue to get it work.
I used VISA R/W to communicated to the device.
There is only one file at the time being named as "boot.ldr".
Any help will be appreciated
attached the code
Message 1 of 8
(3,455 Views)
Questions:
1) Does the device show up as a drive-letter in the OS?
2) Is the device part of the "Mass Storage" USB Class?
3) Are you familiar with low-level USB communication?
If the answer to 1 is YES then simply write files using the normal "Write file" function.
If the answer to 1 is NO then I strongly recommend (assuming the answers to 2 and 3 are YES) you look at THIS Page under "Mass Srtorage".
I don't know anything about Mass Storage commands myself except for the fact that it should be possible with VISA Read and Write (Bulk communication).  As to Filesystem and / or ATAPI comands or such, can't help you there I'm afraid.
Shane.
Message 2 of 8
(3,451 Views)
Hi Shane,
Thanks for the reply, and the tips. I will read it soon.
Attached a snapshot from the code when I run it.
Regard
Guresha
Message 3 of 8
(3,441 Views)
First: that's not a picture of the code, it's a picture of the front panel.
Second: you're obviously dealing with a device which has flash memory internally, not directly with the flash memory itself.  That's a whole different thing.
Third: check the manufacturer's documentation.
Shane.
Message 4 of 8
(3,436 Views)
Hi again,
Sorry, I ment the picture of the front panel.
I attached the code at the first post, but I can attached again.
as you said the device has an internal flash memory and can be stacked together to extend the data memory to 64G.
Guresha
Message 5 of 8
(3,428 Views)
I don't have 8.6 so I can't open the code.  Sorry.
Does the manufacturer deliver documentation for communication?
Shane.
Message 6 of 8
(3,424 Views)
Hi Shane,
It is serial for communicating with RS232.
Regard
Guresha
Message 7 of 8
(3,413 Views)
There are examples for RS232 communications that come with Labview.  Open the example finder window and search for RS232 or Serial.  Study the example vi's, or just copy one and change it to do what you need.
- tbob
Inventor of the WORM Global
Message 8 of 8
(3,383 Views)
