read from excel file stops at column 5(E) returns error at data variant function
hi,
i am read an excel file approx 15 rows by 16 rows.
The vi works fine upto 5 rows and 5 columns and prints data on front panel after using data variant.
The Cell range are also seems to be correct for higher rows/columns but then the errors occurs at data variant to 2d dbl stage.
Any idea what might be wrong in the vi
chintan
(2,482 Views)
We can only guess at what might be wrong with the VI since we can't see it because you didn't attach it.
(2,480 Views)
Thanks for the reply.
I found out what was wrong the data types should be the string type and i was using DBL.
(2,468 Views)
