read from excel file
I have read all thread discussing about reading from excel file but they didn't quite answer my question. So here it is again!
I found the example from NI site that works partially for my need (see attached vi). But I want to modify so it can read my entire excel file, not just 1 row or 1 sheet. Because I plan to update the excel file every once a while with new data. I tried to use "ShowallData" property but couldn't quite figure out. Please give me me some pointers.
dphan128
(3,367 Views)
HI I do not have LV installed on this PC so I cannot give you aan example. Have a look at the excel board where there are many VI's and toolkits for working with excel.
If you still need help I will try to give you an example tomorrow.
For more information and some sample VI's and tool kits, you can go to the excel board
Joe.
"NOTHING IS EVER EASY"
(3,359 Views)
I have found the answer that I need, Thanks
dphan128
(3,338 Views)
Around here we say thank you with ratings
Joe.
(3,332 Views)
