read from measurment file express vi will not read tdms data
I started doing something easy.  Using the Write To Measurement File to save a tdms file, I then tried to read it back using the Read From Measurment File.  No luck, I get error -2525.  I can use the above approach to save and read a lvs file.
What am I missing?
Rick
(2,670 Views)
Rick,
This was reported to R&D (# 45685) for further investigation. The issue appears to be related to the timestamp. There isn'tcurrently a known workaround.
Hillary E
(2,647 Views)
