read from measurment file
Hello
I faced a stupid problem, when I wanna read from my measurement file I can not
and the program will stop suddenly would you please guide me
the error that is shown is "LabVIEW:  End of file encountered."!!!!!!
thanks
(3,121 Views)
That's not a LabVIEW Measurement file. It's an Excel file. And, why do you have the read inside a loop?
(3,118 Views)
Thanks Dennis
I have Labview measurment file but as I could not post it here I post the excel file. thanks for your guidance I deleted the loop but result in this error
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
I am really confused.
thanks man
(3,113 Views)
thanks man
now it is working, thanks you are so helpfull
cheers
(3,108 Views)
