read from spreadsheet file
I would just like some help with my code. I'm trying to read data from "WAV00000.CSV", but I have a problem with the precision of numbers.
Example:
-9.980000E-3 was read as -9,000
How can I solve this problem?
Regards
Message 1 of 8
(4,606 Views)
sljuka wrote:
How can I do that?
Do what? You are not saying what the problem is, but your code seems to work just fine.
(Of course it cannot read the header and thus substitutes zeroes, but you could read the first line seperately, then set the offset accordingly before reading the spreadsheet data. You could also simply delete the first row.)
Message 2 of 8
(4,604 Views)
Ah, OK you edited your question.
Could it be you are using a OS version where the decimal point is a comma? This is basically incompatible with CSV, because you cannot have a comma as decimal seperator and column delimiter at the same time. Your OS does not recognize the period as decimal seperator, and thus truncates the data.
Try a format of "%.;%3e" (percent-period-semicolon-percent-three-e). I cannot test, but it's worth a shot. The "%.;" should force treating the period as decimal point. Check the help.
Message 3 of 8
(4,595 Views)
You should read the rows as string then you can convert Engineering style values to double format number by "Fract/Exp String To Number" function.
I attached the example.
Peter
Peter Vago
Message 4 of 8
(4,551 Views)
You probably have a Labview 2010 and I can not open your example. I have Labview 2009. Can you save this example for my version of Labview?
Message 5 of 8
(4,535 Views)
The example posted above is pointless, because your problem has to do with the localized decimal point. (Your program works just fine in the USA).
Have you tried my suggestion with the format modification? Did it work?
Message 6 of 8
(4,523 Views)
Accepted by topic author sljuka
in 2009
Message 7 of 8
(4,522 Views)
I tried but it didn't work (I don't know why). This last example is OK.
Thanks!
Message 8 of 8
(4,499 Views)
