'read from text file' erases the file
I am trying to read text in from a text file.  This is the exact code I am using.  For some reason the output from 'read from text file' contains all the text that was originally in the file, but after the code executes the file is empty.  I have several other vi's which use the same code and the file is fine.  But whenever I run this code in this one specific vi the text file gets erased.
(2,414 Views)
Ok sorry everybody. I found the problem.  At the far end of my vi I rewrite the file using open -> write -> close  My error line was connected to the front of the write function but not the open function so that open was being executed at the beginning of the vi rather than the end where I intended.
(2,408 Views)
What is in the rest of that "specific vi"? I just tried the code you show, in v2011, and it works as expected, doesn't clear file.
What version are you running? Can you add an error out, or make sure error output is on in your LabVIEW configuration?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,406 Views)
