read from .txt file and output the content as two arrays
I am using the contoured move to control the x-y stage. The trajectory datas for x and y axis are generated using my interpolation program and it is stored in a .txt file as two columns. What I want to do is read .txt file and output the content of this file as two arrays. Is there anyone has any ideas? Thanks, the .txt file is attached.
(2,556 Views)
Hi Awen,
This is quite easy to do, you can merely use the "read from spreadsheet file" function to get a 2D array (2 columns and n rows) and then use the index array function to get whatever row/colums you want..
Hope the attached VI helps you 😉
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,553 Views)
