06-23-2011 03:17 AM
hi all
i want to re-generate the signal using PXI-5412, which is connected to my control speaker using co-axial hardware connection?
i have generated signal using NI-scope , but now my task is reverse that signal is coming which i want to read using AWG pxi-5412 arbitrary wave generate..
i will be thankfull for any kind reply
tc
06-24-2011 09:20 AM
Hi tc,
May I ask you to clarify your application? Are you asking how you can read a waveform on your PXI-5412 Arbitrary Waveform Generator?
Per the specifications, the only inputs you have on your PXI-5412 are the CLK_IN and PFI lines. Which, the CLK_IN line is for an external sample clock and the PFI lines are used to control triggering.
NI PXI/PCI-5412 Specifications
http://www.ni.com/pdf/manuals/371468d.
Kyle S
