read graph
hello,
I would like to read a file of labview measurement but I don't use the icon made for this function because it does not enable me to read the files the ones after the others, there is an error of meeting of end of file. Thus I have another way but the curve is not well and I do not know how to make differently. I joined also a file (txt because one cannot join lvm).
(3,513 Views)
Try this.
Regards
Ray Farmer
Regards
Ray Farmer
(3,491 Views)
It's help me and that's i wanted but i work with labview 7.1. Is it possible to have ex_fileReadTDM.vi with 7.1? Because i tried and Labview say me that i can't.
(3,468 Views)
Bonjour,
Pour lire ton fichier tu dois utiliser la fonction lire un fichier de mesure et non pas la fonction lire un fichier tableur.
ClémentG
(3,450 Views)
En fait je n'ai plus de problème quand je retire la boucle while. Mais si je fais ça il faut que je trouve un moyen de revenir dans mon vi proncipale car car ce module sert de sous-vi.
(3,446 Views)
Here are 7.1 versions
Regards
Ray Farmer
Regards
Ray Farmer
(3,434 Views)
