read ini
Hi all,
i am reading one ini file which contents only texts and i am able to read it properly. Now i want to insert some pictires like circuit diagrams in this file and same things i want to read from the file and want to display on my front pannel of program. is it posiible?
regards
manasi
(3,177 Views)
Hi manasi,
"ini" configuration files are text files. You cannot store pictures in them. But you can store the path to the picture and then read the picture from another file.
(3,169 Views)
Thanks a lot.
i want to import text and bitmaps from word document in picture or string control is it possible?
(3,103 Views)
That's a different question. That requires using ActiveX control over Word. See here for an example that you can start with.
(3,077 Views)
