read jpg file in a loop
Hi All,
I have simple labview code which has a memory leak.
I am creating the file path to the jpg file, and then using the Read JPEG file.vi and Draw Flatten PixMap.vi to display the image.
How can I do this without leaking memory?
In the future, I will have another application which updates the file every so often. I will use some sort of control to stop reading/writing to the file at the same time.
Please help,
James
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(4,461 Views)
Can you post a screen shot to show where the mem leak is? Do you have VDM(vision development module)?
(4,445 Views)
Hi James
I just tried it here in 8.5.1 and a don't see memory leak.
I am going to guess that you may have the picture data in a shift register and feeding the previous iteration into Draw Flattened Pixmap picture input. Have a look inside Draw Flattened Pixmap. Its basically concatentating strings which may be your the leak you are seeing.
cheers
David
(4,426 Views)
Hi everyone - thanks for the replies.
My simple mock up of the issue looks like :
The LabVIEW.exe memory increases by 5,000k per iteration of the loop. This is concerning.
Is this to be expected?
Can it be avoided?
Should I consider another apporach?
PS I do not have the VDM.
THANKS!
James
Message Edited by Hillman on 03-27-2010 11:29 AM
Kind Regards
James Hillman
(4,409 Views)
Accepted by topic author Hillman
Hi James,
i think the reason is, that you use a shift register. The "Draw Flattened Pixmap" functions adds the new image every iteration to the old one.
Mike
(4,406 Views)
Thanks mike! That worked  - obviously. I felt like I must have been missing using the VI.
Have a great weekend,
James
Kind Regards
James Hillman
(4,401 Views)
Thanks a lot
You recomadation working for me.
Best Regards
(3,553 Views)
