read lvm in a loop
I have lvm files in a folder that were generated through data acquisition.
I want to recobine the files and compress some columns of the data.
I have made the attached vi but it does not get all the files in the folder.
I would appreciate help in doing the following:
1) having some way of picking some consecutive files, lets say files
dat_002, dat_003, dat_004, dat_005....... dat_050
and getting the output of the wanted columns with compressed in the
output lvm file.
2) having some way of getting the above done for all files in the folder.
Any help will be appreciated.
Thanks.
(3,007 Views)
Hi magreent,
you can use the "List Directory" function or if you have LV8.5 or above, then you can use the "Recursive File List.vi" to list all files from your specified folder.
Mike
(2,987 Views)
Would you mind adding the recursive list and list directory functions to my vi.
I have been playing around with it and I am not getting what I am trying to do.
Thanks.
(2,951 Views)
Here is the attachment.
(2,948 Views)
